- Joined
- Jun 21, 2009
- Messages
- 1,257
- Helped
- 292
- Reputation
- 592
- Reaction score
- 305
- Trophy points
- 1,363
- Location
- Japan
- Activity points
- 12,987
Hello!
I am designing a board that can drive DC motors and servos. The servos are plain RC model servos,
and they can be powered from "3.5 to 8 V under load" (that's what is written on the box).
My board can drive basically any DC motor up to 500 mA and from 3V to 15V (There is an input voltage
measurement so that the PWM adapts automatically for low voltage motors. Of course, you have to set
up the motor voltage).
So, assuming that the board will be powered between, say, 3.6 and 15V (3.6 would be 3 NimH batteries),
I need a system to limit the servo voltage. So I was thinking about a 7.5V LDO. This would work fine
if the input voltage is higher than 7.5 (+ dropout), but what about lower voltages?
Is there any problem in feeding a 7.5V LDO with, say, 4.5V? My feeling is that the LDO would pass
everything because the input is lower that its nominal value, but is there a hidden problem in doing that?
Thanks,
Dora.
Thanks,
Dora.
