LCD1602 with Arduino I2C, RS is working for command calls but not for data
eagle1109
Full Member level 6
Saudi Arabia
My configuration is:
LCD1602, I2C adapter and Arduino nano.
Sending commands works fine but I can't display chars by sending data.
That happens when set the RS pin to high for data and low for commands.
So what's happening is that the two functions for sending commands and data works the same.
I concluded that I have a problem with sending data, if I edit the RS bit in command function to high or low the function is the same.
So, the problem is with RS pin.
This is my code:
#define E   2   // E  bit
#define RW  1   // RW bit
#define RS  0   // RS bit
#define LCDadd_WR  0x4E
#define LCDadd_RD  0x4F
uint8_t bitmask = 0x08;
uint8_t i, arr[]={0x48,0x65,0x6c,0x6c,0x6f ,0x10 ,0x3a,0x29 ,0x10 ,0x48,0x6f,0x77,0x10
,0x61,0x72,0x65,0x10,0x79,0x6f,0x75,0x65,0x76,0x65,0x72,0x79,0x10,0x6f,0x6e,0x65};
// LCD prototypes
void LCD_Init(void);
void sendCMD(uint8_t CMD);
void sendData(uint8_t data);
void LCD_string(uint8_t arr1[]);
void move_cursor (uint8_t row, uint8_t col);
// I2C prototypes
void I2C_init(void);
void I2C_start(uint8_t address);
void I2C_stop(void);
void I2C_tx(uint8_t data);
void I2C_TWSR_Check(void);
void setup() {
  Serial.begin(9600);
I2C_init();
LCD_Init();
void loop() {
//sendData("H");
void LCD_Init(void)
  sendCMD(0x33);
  sendCMD(0x32);
  sendCMD(0x28);
  sendCMD(0x0E);
  sendCMD(0x01);
  bitmask = 0x08;
  I2C_start(LCDadd_WR);
  I2C_tx(bitmask |= (1<<RS));
  I2C_tx(bitmask &= ~(1<<RW));
  I2C_tx(bitmask = CMD & 0xF0 | 0x08);
  Serial.println("CMD high");
  Serial.println(bitmask, HEX);
  _delay_ms(5);
  I2C_tx(bitmask |= (1<<E));
  _delay_ms(1);
  I2C_tx(bitmask &= ~(1<<E));
  _delay_ms(1);
  I2C_tx(bitmask = (CMD<<4) & 0xF0 | 0x08);
  Serial.println("CMD low");
  _delay_ms(1);
  I2C_stop();
  bitmask = 0x08;
  Serial.println("data");
  I2C_tx(bitmask = data & 0xF0 | 0x08);
  _delay_ms(5);
  _delay_ms(1);
  _delay_ms(1);
  I2C_tx(bitmask = (data<<4) & 0xF0 | 0x08);
  _delay_ms(1);
  I2C_stop();
uint8_t BF(void)
  I2C_tx(bitmask &= ~(1<<RS));
  I2C_tx(bitmask |= (1<<RW));
  I2C_stop();
  I2C_start(LCDadd_RD);
  I2C_rx();
  while (!(TWDR == (bitmask & (bitmask<<3))));
  I2C_stop();
  _delay_ms(500);
  _delay_ms(500);
  I2C_stop();
  if (row==1)
  sendCMD(0x80+col);
  if (row==2)
  sendCMD(0xC0+col);
uint8_t cnt=0;
  for (i=0;i<29;i++)
    sendData(arr1[i]);
    _delay_ms(500);
    cnt++;
    if (cnt==16)
    sendCMD(0xC0);
  sendData(0x10);
void I2C_init(void)
  //set SCL to 100kHz
  TWSR = 0x00;
  TWBR = 0x48;
  //enable TWI
  TWCR = (1<<TWEN);
  TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
  while (!(TWCR & (1<<TWINT)));
  TWDR = address;
  TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWEA);
void I2C_stop(void)
  TWCR = (1<<TWINT)|(1<<TWSTO)|(1<<TWEN);
  TWDR = data;
uint8_t I2C_rx(void)
  return TWDR;
Regards,
You should set RS low in sendCMD() and high in sendData(), but you don't.
It's set low in both routines because the control line state is overwritten by
respectively
The bit pattern should be set in a single I2C_tx() action before pulsing E line.
Code can be simplified like below. I2C_tx() is providing more delay than necessary if busy polling is performed.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
  I2C_stop();
  I2C_tx(bitmask = data & 0xF0 | 0x08 |= (1<<RS));
  I2C_tx(bitmask = (data<<4) & 0xF0 | 0x08 |= (1<<RS));
  I2C_stop();
Thank you very much, that solved the problem.
Now I have another issue, which is how to read a command or data from the LCD?
I'm developing this new function, but with the serial print, I don't see the values I'm expecting.
void lcdCMD_read (void)
  Serial.println("enter function");
  I2C_start(LCDadd_WR);           // write PCF8574 address
  I2C_tx(bitmask |= 0x0B);        // RS, RW = 1 read data
  I2C_stop();
  Serial.println("i2c stop");
  I2C_start(LCDadd_RD);           // read PCF8574 address
  I2C_rx();                       // receive I2C and get TWDR
  Serial.println(TWDR, HEX);      // print TWDR
  //while (!(TWDR == (bitmask & (bitmask<<7))));  // This function never ends
  Serial.println("CMD from LCD");
  I2C_stop();
