Lcd not working [JHD162A] 16x2
armghan11
Member level 1
Member level 1
i wrote a little code to test lcd... the code working fine on proteus but on hardware lcd dont show any character...
#include <16F877A.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay(clock=4000000)
#include <flex_lcd.c>
void main()
lcd_init();
lcd_putc("Hello World");
while(true)
output_high(Pin_C3);
     delay_ms(1000);
     output_low(PIN_C3);
     delay_ms(1000);
while(1);
Flex_lcd.c Driver
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver.  Change these
// pins to fit your own board.
#define LCD_DB4   PIN_B4
#define LCD_DB5   PIN_B5
#define LCD_DB6   PIN_B6
#define LCD_DB7   PIN_B7
#define LCD_E     PIN_D6
#define LCD_RS    PIN_D7
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
// #define USE_LCD_RW   1
#define lcd_type 2        // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
 0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
 0xc,                    // Display on
 1,                      // Clear display
 6                       // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
 output_bit(LCD_DB4, !!(nibble & 1));
 output_bit(LCD_DB5, !!(nibble & 2));
 output_bit(LCD_DB6, !!(nibble & 4));
 output_bit(LCD_DB7, !!(nibble & 8));
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine.  For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return(retval);
#endif
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
   output_high(LCD_RS);
else
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
#endif
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
    lcd_send_nibble(0x03);
    delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
    lcd_send_byte(0, LCD_INIT_STRING[i]);
    // If the R/W signal is not used, then
    // the busy bit can't be polled.  One of
    // the init commands takes longer than
    // the hard-coded delay of 60 us, so in
    // that case, lets just do a 5 ms delay
    // after all four of them.
    #ifndef USE_LCD_RW
    delay_ms(5);
    #endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
   address = lcd_line_two;
else
   address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      delay_ms(2);
      break;
    case '\n':
       lcd_gotoxy(1,2);
       break;
    case '\b':
       lcd_send_byte(0,0x10);
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
#endif
void lcd_setcursor_vb(short visible, short blink) {
  lcd_send_byte(0, 0xC|(visible<<1)|blink);
I grounded the R/w Pin ...
and connected all other pins according to the flex_lcd driver
I am using 3.9v battery... is this the problem? cause right now i dont have any other
Ensure Oscillator works good as mentioned by hemnath. Is it XT or HS in the fuses?
Put a small delay after the lcd_init(); function to let the lcd initialize. about 10-20ms would do.
for a frequency less than or equal to 4mhz its XT... and HS for greater than 4mhz
and ok i will try adding some delay
