LCD Interface problem with 16f877a
pany2008
Junior Member level 3
India
Hi
I am using the 16x2 lcd and interfacing it with 4 bit mode, i am placing the source please suggest what is wrong, the display is showing only the cursor blink but it is not displaying the message.
main program
#include<pic.h>
#include "ioports1.h"
#include "delay.h"
#include "lcd.h"
__CONFIG (DEBUGDIS & WDTDIS & BORDIS & PWRTDIS & HS & LVPDIS & PROTECT);
extern init_ports();
void Sec(unsigned int);
void main()
init_ports();
Sec(200);
lcd_init(); //LCD initialized
Sec(100);
lcd_line1(0); //LCD address specified AT LINE 1
lcd_string("INTERFACING LCD"); //Displays message "LCD INTERFACING"
lcd_line2(0); //LCD address specified AT LINE 2
lcd_string(" PIC 16F877A");//Displays message " PIC 16f877a"
for(;
LED1 = !LED1;
Sec(300);
LED1 = !LED1;
Sec(300);
init_ports()
T_LED1 = 0; // pin enable to output
LED1 = 1;
T_LED2 = 0; // pin enable to output
LED2 = 1;
T_LED3 = 0; // pin enable to output
LED3 = 1;
void Sec(unsigned int itime)
unsigned int i;
unsigned char j;
for(i=0;i<itime;i++)
for(j=0;j<165;j++);
lcd.c file code
#include <htc.h>
#include "lcd.h"
#include "ioports.h"
//#define LCD_RS RB6
//#define LCD_RW RB5
//#define LCD_EN RB4
#define LCD_DATA PORTB
#define LCD_STROBE() ((LCD_EN = 1),(LCD_EN=0))
/* write a byte to the LCD in 4 bit mode */
void
lcd_write(unsigned char c)
unsigned char d;
__delay_us(40);
LCD_DATA = ( ( c >> 4 ) & 0x0F );
LCD_STROBE();
LCD_DATA = (c & 0x0F);
LCD_STROBE();
__delay_us(40);
* Clear and home the LCD
void
lcd_clear(void)
LCD_RS = 0;
lcd_write(0x1);
__delay_ms(2);
/* write a string of chars to the LCD */
void
lcd_string(const char * s)
LCD_RS = 1; // write characters
while(*s)
lcd_write(*s++);
/* write one character to the LCD */
void
lcd_character(char c)
lcd_write( c );
* Go to the specified position in line 1
void
lcd_line1(unsigned char pos)
LCD_RS = 0;
lcd_write(0x80+pos);
* Go to the specified position in line 2
void
lcd_line2(unsigned char pos)
LCD_RS = 0;
lcd_write(0xC0+pos);
* Go to the specified position in line 3
void
lcd_line3(unsigned char pos)
LCD_RS = 0;
lcd_write(0x94+pos);
* Go to the specified position in line 4
void
lcd_line4(unsigned char pos)
LCD_RS = 0;
lcd_write(0xD4+pos);
/* initialise the LCD - put into 4 bit mode */
void
lcd_init()
char init_value;
T_LCD_RS = 0; // pin enable to output
LCD_RS = 0;
T_LCD_RW = 0; // pin enable to output
LCD_RW = 0;
T_LCD_EN = 0; // pin enable to output
LCD_EN = 0;
T_LCD_D0 = 0; // pin enable to output
LCD_D0 = 0;
T_LCD_D1 = 0; // pin enable to output
LCD_D1 = 0;
T_LCD_D2 = 0; // pin enable to output
LCD_D2 = 0;
T_LCD_D3 = 0; // pin enable to output
LCD_D3 = 0;
init_value = 0x3;
// PORTB = 0x00;
// TRISB = 0x00;
LCD_RS = 0;
LCD_EN = 0;
LCD_RW = 0;
__delay_ms(15); // wait 15mSec after power applied,
LCD_DATA = init_value;
LCD_STROBE();
__delay_ms(5);
LCD_STROBE();
__delay_us(200);
LCD_STROBE();
__delay_us(200);
LCD_DATA = 2; // Four bit mode
LCD_STROBE();
lcd_write(0x28); // Set interface length
lcd_write(0xF); // Display On, Cursor On, Cursor Blink
lcd_clear(); // Clear screen
lcd_write(0x6); // Set entry Mode
lcd.h
extern void lcd_write(unsigned char);
/* Clear and home the LCD */
extern void lcd_clear(void);
/* write a string of characters to the LCD */
extern void lcd_string(const char * s);
/* Go to the specified position in line 1 */
extern void lcd_line1(unsigned char pos);
/* Go to the specified position in line 2 */
extern void lcd_line2(unsigned char pos);
/* Go to the specified position in line 3 */
extern void lcd_line3(unsigned char pos);
/* Go to the specified position in line 4 */
extern void lcd_line4(unsigned char pos);
/* intialize the LCD - call before anything else */
extern void lcd_init(void);
extern void lcd_character(char);
/* Set the cursor position */
#define lcd_cursor(x) lcd_write(((x)&0x7F)|0x80)
ioports.h
#ifndef BITNUM
#define BITNUM(adr, bit) ((unsigned)(&adr)*8+(bit)) //-- used for port defs
#endif
static bit LCD_RS @ BITNUM(PORTB,6);
static bit T_LCD_RS @ BITNUM(TRISB,6);
static bit LCD_RW @ BITNUM(PORTB,5);
static bit T_LCD_RW @ BITNUM(TRISB,5);
static bit LCD_EN @ BITNUM(PORTB,4);
static bit T_LCD_EN @ BITNUM(TRISB,4);
static bit LCD_D0 @ BITNUM(PORTB,0);
static bit T_LCD_D0 @ BITNUM(TRISB,0);
static bit LCD_D1 @ BITNUM(PORTB,1);
static bit T_LCD_D1 @ BITNUM(TRISB,1);
static bit LCD_D2 @ BITNUM(PORTB,2);
static bit T_LCD_D2 @ BITNUM(TRISB,2);
static bit LCD_D3 @ BITNUM(PORTB,3);
static bit T_LCD_D3 @ BITNUM(TRISB,3);
delay.c
void
DelayMs(unsigned char cnt)
#if XTAL_FREQ <= 2MHZ
do {
DelayUs(996);
} while(--cnt);
#endif
#if XTAL_FREQ > 2MHZ
unsigned char i;
do {
i = 4;
do {
DelayUs(250);
} while(--i);
} while(--cnt);
#endif
delay.h
#ifndef XTAL_FREQ
#define XTAL_FREQ 12MHZ /* Crystal frequency in MHz */
#endif
#define MHZ *1000L /* number of kHz in a MHz */
#define KHZ *1 /* number of kHz in a kHz */
#if XTAL_FREQ >= 12MHZ
#define DelayUs(x) { unsigned char _dcnt; \
_dcnt = (x)*((XTAL_FREQ)/(12MHZ)); \
while(--_dcnt != 0) \
continue; }
#else
_dcnt = (x)/((12MHZ)/(XTAL_FREQ))|1; \
continue; }
#endif
extern void DelayMs(unsigned char);
ioports1.h
#ifndef BITNUM
#endif
static bit LED1 @ BITNUM(PORTD,7); //-- LED
static bit T_LED1 @ BITNUM(TRISD,7);
static bit LED2 @ BITNUM(PORTD,3); //-- LED
static bit T_LED2 @ BITNUM(TRISD,3);
static bit LED3 @ BITNUM(PORTD,2); //-- LED
static bit T_LED3 @ BITNUM(TRISD,2);
please if any one can guide me my problem
You should adjust your portpins to digital
ADCON1=&1010 or something like based on your compiler
Hai thanks for help but i am right now using the only PORTB for LCD display so it is not and analog input pin but its totally digital pin no need to adjust ADCON1 in it.
your routines / structure are generally poorly thought out, and the issues are numerous.
take for example your lcd_write() routine. Since your control lines are on the same port as your lcd, when you perform something like:
you have destroyed the states of those non-lcd-data pins (RS/EN/RW pins).
Millwood is right.
These routines look like from the Hi-Tech C LCD interface example.
If you want all the pins from the same port you need to save the port state and 'or' it.
like:
 LCD_DATA = ((LCD_DATA & 0xF0) | ( c >> 4 ) & 0x0F );
 //                    XXXX 0000 | 0000 YYYY   =  XXXXYYYY
//note the last 4 bits on the port remain un changed
The Hitech C example is a bit crude because it assumes that you do not use the higher 4 bits of the port as output.
that speaks volume about hitech, doesn't it?
It does kind of yes, but its the application engineers to blame. I like HiTech, been using it for quite a while now and sometimes the efficiency is brilliant. Now that its been acquired by Microchip I wonder where they are heading.
i just want to give suggestion, i think it much better use BASIC for display 2 x 16 lcd..u can use PICBasic or Proton IDE..for example u want display "Hello World", the command u should use is
Print at 1,1, "Hello World"
Here is the code for main...
	init();
	DelayMs(100);
	lcd_init();
	DelayMs(100);
	lcd_goto(0);	// select first line
	DelayMs(100);
	lcd_puts("12345678");
	DelayMs(100);
	lcd_goto(0x40);	// Select second line
	DelayMs(100);
	lcd_puts("Hello World");
	DelaySec(10);
	lcd_clear();
	DelayMs(100);
	lcd_message("Line 1",1);
	DelayMs(100);
	lcd_message("Line 2",2);
	DelayMs(100);
	lcd_message("Line 3",3);
	DelayMs(100);
	lcd_message("Line 4",4);
	DelaySec(10);
	lcd_clear();
	DelayMs(100);
Thanks to everyone for the great help now the lcd display is working fine with all off yours help, now i need one more help please help me.
I am posting schematic here in which i am using the key board on the 4 bit data line of lcd, and common from 4 key is taken to the PORT RB7, i am not able to sense the key, and even lcd also show some junk character in the lcd when any of the key is pressed please provide me some help.
static bit KEY1 @ BITNUM(PORTB,0); //-- KEY
static bit T_KEY1 @ BITNUM(TRISB,0);
static bit KEY2 @ BITNUM(PORTB,1); //-- KEY
static bit T_KEY2 @ BITNUM(TRISB,1);
static bit KEY3 @ BITNUM(PORTB,2); //-- KEY
static bit T_KEY3 @ BITNUM(TRISB,2);
static bit KEY4 @ BITNUM(PORTB,3); //-- KEY
static bit T_KEY4 @ BITNUM(TRISB,3);
static bit KEY_RT @ BITNUM(PORTB,7); //-- KEY
static bit T_KEY_RT @ BITNUM(TRISB,7);
for loop routine
for(;
key_check();
copy_adc_values();
convert_adc_temp_values();
convert_adc_pt_values();
update_lcd();
Key check routine
key_check()
T_LCD_RW = 0;
LCD_RW = 1;
T_LCD_RS = 0;
LCD_RS = 1;
T_LCD_EN = 0;
LCD_EN = 0;
T_KEY1 = 0; // pin enable to output
T_KEY2 = 0; // pin enable to output
T_KEY3 = 0; // pin enable to output
T_KEY4 = 0; // pin enable to output
T_KEY_RT = 1; // pin enable to input
KEY_RT = 1;
KEY1 = KEY2 = KEY3 = KEY4 = 1;
++key_cnt;
switch(key_cnt)
case 1: KEY1 = 0;
break;
case 2: KEY2 = 0;
KEY1 = KEY3 = KEY4 = 1;
break;
case 3: KEY3 = 0;
KEY2 = KEY1 = KEY4 = 1;
break;
case 4: KEY3 = 0;
KEY2 = KEY3 = KEY1 = 1;
break;
switch(key_cnt)
case 1: if(!KEY_RT)
up_flag = 1;
key1_flag = 1;
keyno = 1;
else if(KEY_RT)
up_flag = 0;
key1_flag = 0;
break;
case 2: if(!KEY_RT)
dn_flag = 1;
key2_flag = 1;
keyno = 2;
else if(KEY_RT)
dn_flag = 0;
key2_flag = 0;
break;
case 3: if(!KEY_RT)
set_flag = 1;
key3_flag = 1;
keyno = 3;
else if(KEY_RT)
set_flag = 0;
key3_flag = 0;
break;
case 4: if(!KEY_RT)
ent_flag = 1;
key4_flag = 1;
keyno = 4;
else if(KEY_RT)
ent_flag = 0;
key4_flag = 0;
break;
if(key_cnt >= 5) key_cnt = 0;
if((key1_flag) || (key2_flag) || (key3_flag) || (key4_flag)) key_flag = 1;
else if((!key1_flag) && (!key2_flag) && (!key3_flag) && (!key4_flag))
key_flag = 0;
keyno = 0;
// if(!key_flag)
T_KEY_RT = 0; // pin enable to output
KEY_RT = 0;
TRISB = 0X00;
// PORTB = 0X00;
LCD_RW = 0;
LCD_RS = 0;
I am using PIC16F628A with 2x16 lcd and hi tech c example. I modified this example for my case. I am using RB0 for external interrupt, so I can't "and" the data with lower 4 bits of PORTB, so I changed the code for higher 4 bits to compare with data. LCD initializes perfect, but it's displaying some strange chars (like @ and some chineese letters). Can someone look at my case, please?
#include	"main.h"
#ifndef	_XTAL_FREQ
#define	_XTAL_FREQ	4000000
#endif
#define	LCD_RS RA2
#define LCD_EN RA3
#define	LCD_STROBE()	((LCD_EN=1),(__delay_us(1)),(LCD_EN=0),(__delay_us(1)))
void
	__delay_us(45);
	LCD_DATA = (c&0xf0);	//pošljemo zgornje 4 bite
	LCD_STROBE();
	LCD_DATA = ((c>>4)&0xf0);	//pošljemo spodnje 4 bite
	LCD_STROBE();
	__delay_us(45);
void
lcd_clear(void)
	LCD_RS = 0;
	lcd_write(0x01);
	__delay_ms(3);
void
lcd_puts(const char * s)
	for(;*s;*s++)
		lcd_write(*s);
void
lcd_putch(char c)
	lcd_write( c );
void
lcd_goto(unsigned char pos)
	LCD_RS = 0;
void
lcd_init()
	__delay_ms(40);	// zakasnitev za stabilizacijo elektronike LCD-ja
	LCD_RS=0;
	LCD_DATA=0x3;
	LCD_STROBE();
	__delay_ms(10);
	LCD_DATA=0x3;
	LCD_STROBE();
	__delay_us(200);
	LCD_DATA=0x3;
	LCD_STROBE();
	__delay_ms(5);
	LCD_DATA=0x2;
	LCD_STROBE();
	__delay_us(200);
	lcd_write(0x28);
	lcd_write(0x08);
	lcd_clear();
	lcd_write(0x06);
	lcd_write(0x0f);
