[SOLVED] LCD display for ups using for mains, ups, charging and battery full indicators
iqbalpiac
Newbie
Lcd display for ups using for mains,ups ,charging and battery full indications
#include <avr/io.h>
#include <inttypes.h>
#ifndef F_CPU
	#define F_CPU 8000000UL
#endif
#include <util/delay.h>
#include "lcd.h"
#include "custom_char.h"
#define LCD_DATA_PORT 	PORT(LCD_DATA)
#define LCD_E_PORT 		PORT(LCD_E)
#define LCD_RS_PORT 	PORT(LCD_RS)
#define LCD_RW_PORT 	PORT(LCD_RW)
#define LCD_DATA_DDR 	DDR(LCD_DATA)
#define LCD_E_DDR 		DDR(LCD_E)
#define LCD_RS_DDR 		DDR(LCD_RS)
#define LCD_RW_DDR 		DDR(LCD_RW)
#define LCD_DATA_PIN	PIN(LCD_DATA)
#define SET_E() (LCD_E_PORT|=(1<<LCD_E_POS))
#define SET_RS() (LCD_RS_PORT|=(1<<LCD_RS_POS))
#define SET_RW() (LCD_RW_PORT|=(1<<LCD_RW_POS))
#define CLEAR_E() (LCD_E_PORT&=(~(1<<LCD_E_POS)))
#define CLEAR_RS() (LCD_RS_PORT&=(~(1<<LCD_RS_POS)))
#define CLEAR_RW() (LCD_RW_PORT&=(~(1<<LCD_RW_POS)))
#define LCD_LINE0_DDRAMADDR		0x00
#define LCD_LINE1_DDRAMADDR		0x40
#define LCD_LINE2_DDRAMADDR		0x10
#define LCD_LINE3_DDRAMADDR		0x50
#define LCD_DDRAM           7	//DB7: set DD RAM address
void LCDcursorLeft(uint8_t n)	//Moves cursor by n poisitions left
	uint8_t i;
	for (i=0;i<n;i++)
		LCDCmd(0x10);
void LCDByte(uint8_t c,uint8_t isdata)
//Sends a byte to the LCD in 4bit mode
//cmd=0 for data
//cmd=1 for command
//NOTE: THIS FUNCTION RETURS ONLY WHEN LCD HAS PROCESSED THE COMMAND
uint8_t hn,ln;			//Nibbles
uint8_t temp;
hn=c>>4;
ln=(c & 0x0F);
if(isdata==0)
	CLEAR_RS();
else
	SET_RS();
_delay_us(0.500);		//tAS
SET_E();
//Send high nibble
temp=(LCD_DATA_PORT & 0XF0)|(hn);
LCD_DATA_PORT=temp;
_delay_us(1);			//tEH
//Now data lines are stable pull E low for transmission
CLEAR_E();
_delay_us(1);
//Send the lower nibble
SET_E();
temp=(LCD_DATA_PORT & 0XF0)|(ln);
LCD_DATA_PORT=temp;
_delay_us(1);			//tEH
//SEND
CLEAR_E();
_delay_us(1);			//tEL
LCDBusyLoop();
void LCDBusyLoop()
	//This function waits till lcd is BUSY
	uint8_t busy,status=0x00,temp;
	//Change Port to input type because we are reading data
	LCD_DATA_DDR&=0xF0;
	//change LCD mode
	SET_RW();		//Read mode
	CLEAR_RS();		//Read status
	//Let the RW/RS lines stabilize
	_delay_us(0.5);		//tAS
	do
		SET_E();
		//Wait tDA for data to become available
		_delay_us(0.5);
		status=LCD_DATA_PIN;
		status=status<<4;
		_delay_us(0.5);
		//Pull E low
		CLEAR_E();
		_delay_us(1);	//tEL
		SET_E();
		_delay_us(0.5);
		temp=LCD_DATA_PIN;
		temp&=0x0F;
		status=status|temp;
		busy=status & 0b10000000;
		_delay_us(0.5);
		CLEAR_E();
		_delay_us(1);	//tEL
	while(busy);
	CLEAR_RW();		//write mode
	//Change Port to output
	LCD_DATA_DDR|=0x0F;
void InitLCD(uint8_t style)
	This function Initializes the lcd module
	must be called before calling lcd related functions
	Arguments:
	style = LS_BLINK,LS_ULINE(can be "OR"ed for combination)
	LS_BLINK :The cursor is blinking type
	LS_ULINE :Cursor is "underline" type else "block" type
	//After power on Wait for LCD to Initialize
	_delay_ms(30);
	//Set IO Ports
	LCD_DATA_DDR|=(0x0F);
	LCD_E_DDR|=(1<<LCD_E_POS);
	LCD_RS_DDR|=(1<<LCD_RS_POS);
	LCD_RW_DDR|=(1<<LCD_RW_POS);
	LCD_DATA_PORT&=0XF0;
	CLEAR_E();
	CLEAR_RW();
	CLEAR_RS();
	//Set 4-bit mode
	_delay_us(0.3);	//tAS
	SET_E();
	LCD_DATA_PORT|=(0b00000010); //[B] To transfer 0b00100000 i was using LCD_DATA_PORT|=0b00100000
	_delay_us(1);
	CLEAR_E();
	_delay_us(1);
	//Wait for LCD to execute the Functionset Command
	LCDBusyLoop();                                    //[B] Forgot this delay
	//Now the LCD is in 4-bit mode
	LCDCmd(0b00001100|style);	//Display On
	LCDCmd(0b00101000);			//function set 4-bit,2 line 5x7 dot format
	/* Custom Char */
	LCDCmd(0b01000000);
	uint8_t __i;
	for(__i=0;__i<sizeof(__cgram);__i++)
		LCDData(__cgram[__i]);
	LCDGotoXY(0,0);
/*void LCDWriteString(const char *msg)
	This function Writes a given string to lcd at the current cursor
	location.
	Arguments:
	msg: a null terminated string to print
 while(*msg!='\0')
	LCDData(*msg);
	msg++;
void LCDWriteInt(int val,unsigned int field_length)
	This function writes a integer type value to LCD module
	Arguments:
	1)int val	: Value to print
	2)unsigned int field_length :total length of field in which the value is printed
	must be between 1-5 if it is -1 the field length is no of digits in the val
	char str[5]={0,0,0,0,0};
	int i=4,j=0;
	while(val)
	str[i]=val%10;
	val=val/10;
	i--;
	if(field_length==-1)
		while(str[j]==0) j++;
	else
		j=5-field_length;
	if(val<0)
	LCDData('-');
	for(i=j;i<5;i++)
	LCDData(48+str[i]);
/*void LCDGotoXY(uint8_t x,uint8_t y)
 if(x<40)
  if(y) x|=0b01000000;
  x|=0b10000000;
  LCDCmd(x);
	location.
	Arguments:
	Their are 8 custom char in the LCD they can be defined using
	"LCD Custom Character Builder" PC Software.
	You can print custom character using the % symbol. For example
	to print custom char number 0 (which is a degree symbol), you
	need to write
		LCDWriteString("Temp is 30%0C");
								  |----> %0 will be replaced by
								  		custom char 0.
	So it will be printed like.
		Temp is 30°C
	In the same way you can insert any syblom numbered 0-7
 while(*msg!='\0')
 	//Custom Char Support
	if(*msg=='%')
		msg++;
		int8_t cc=*msg-'0';
		if(cc>=0 && cc<=7)
			LCDData(cc);
		else
			LCDData('%');
			LCDData(*msg);
	else
		LCDData(*msg);
	msg++;
void LCDGotoXY(uint8_t x, uint8_t y)	//Cursor to X Y position
	register uint8_t DDRAMAddr;
	// remap lines into proper order
	switch(y)
	case 0: DDRAMAddr = LCD_LINE0_DDRAMADDR+x; break;
	case 1: DDRAMAddr = LCD_LINE1_DDRAMADDR+x; break;
	//case 2: DDRAMAddr = LCD_LINE2_DDRAMADDR+x; break;
	//case 3: DDRAMAddr = LCD_LINE3_DDRAMADDR+x; break;
	default: DDRAMAddr = LCD_LINE0_DDRAMADDR+x;
	// set data address
	LCDCmd( 1<< LCD_DDRAM | DDRAMAddr);
void LCDcursorOFF(void)	//turns OFF cursor
	LCDCmd(0x0C);
void LCDrewindarrow(void)	//turns OFF cursor
	unsigned int i;
	 //uint16_t string[10]={0x03, 0x07, 0x0F, 0x1F, 0x0F, 0x07, 0x03, 0x00};
	 uint16_t string[8]={0x0E, 0x11, 0x11, 0x11, 0x11, 0x13, 0x17, 0x1F}; //Char0
	for (i=0;i<8;i++)
	LCDData(string[i]);
Re: Lcd display for ups using for mains,ups ,charging and battery full indications
Do you have any questions regarding your project? Otherwise the post is off-topic because this isn't a blog to show your codes?
I will post code
