LCD C code Explanation - DSPIC33 with EXPLORER 16
bubble_d
Junior Member level 3
Hi everyone,
So I have this code which I use for LCD initializations and as I go through them I realize that I actually do not understand what each subroutine does!
Obviously I see the function name is LCD_INIT which will no doubt initialize the LCD but I still do not understand why these certain ports need to be turned on and off.
here is the code I have
#include "p33FJ256GP710a.h"
#include "lcd.h"
#include "delay.h"
#include <stdio.h>
#include <stdlib.h>
   For Explorer 16 board, here are the data and control signal definitions
   RS -> RB15
   E  -> RD4
   RW -> RD5
   DATA -> RE0 - RE7
// Control signal data pins
#define  RW  LATDbits.LATD5       // LCD R/W signal
#define  RS  LATBbits.LATB15      // LCD RS signal
#define  E   LATDbits.LATD4       // LCD E signal
//#define  E   LATFbits.LATF1       // LCD E signal
// Control signal pin direction
#define  RW_TRIS	TRISDbits.TRISD5
#define  RS_TRIS	TRISBbits.TRISB15
#define  E_TRIS		TRISDbits.TRISD4
//#define  E_TRIS		TRISFbits.TRISF1
// Data signals and pin direction
#define  DATA      LATE           // Port for LCD data
#define  DATAPORT  PORTE
#define  TRISDATA  TRISE          // I/O setup for data Port
/*****	LCD SUBROUTINE  *****/
void Init_LCD( void )             // initialize LCD display
	// 15mS delay after Vdd reaches nnVdc before proceeding with LCD initialization
	// not always required and is based on system Vdd rise rate
	Delay(Delay_15mS_Cnt);                  // 15ms delay
	/* set initial states for the data and control pins */
	LATE &= 0xFF00;
    RW = 0;                       // R/W state set low
	RS = 0;                       // RS state set low
	E = 0;                        // E state set low
	/* set data and control pins to outputs */
	TRISE &= 0xFF00;
 	RW_TRIS = 0;                  // RW pin set as output
	RS_TRIS = 0;                  // RS pin set as output
	E_TRIS = 0;                   // E pin set as output
	/* 1st LCD initialization sequence */
	DATA &= 0xFF00;
    DATA |= 0x0038;
    E = 1;
    Nop();
    Nop();
    Nop();
    E = 0;                        // toggle E signal
   	Delay(Delay_5mS_Cnt);         // 5ms delay
	/* 2nd LCD initialization sequence */
	DATA &= 0xFF00;
    DATA |= 0x0038;
    E = 1;
    Nop();
    Nop();
    Nop();
    Delay_Us( Delay200uS_count ); // 200uS delay
	/* 3rd LCD initialization sequence */
	DATA &= 0xFF00;
    DATA |= 0x0038;
    E = 1;
    Nop();
    Nop();
    Nop();
    lcd_cmd( 0x38 );              // function set
    lcd_cmd( 0x0C );              // Display on/off control, cursor blink off (0x0C)
    lcd_cmd( 0x06 );			  // entry mode set (0x06)
void lcd_cmd( char cmd )          // subroutiune for lcd commands
//	TRISD &= 0xFF00;              // ensure RD0 - RD7 are outputs
	DATA &= 0xFF00;               // prepare RD0 - RD7
    DATA |= cmd;                  // command byte to lcd
	RW = 0;                       // ensure RW is 0
    RS = 0;
    E = 1;                        // toggle E line
    Nop();
    Nop();
    Nop();
    E = 0;
void lcd_data( char data )        // subroutine for lcd data
    RS = 1;                       // assert register select to 1
    DATA |= data;                 // data byte to lcd
    E = 1;
 	Nop();
    Nop();
    Nop();
    RS = 0;                      // negate register select to 0
void puts_lcd( unsigned char *data )
	unsigned char count = strlen(data);
  	while ( count )
		lcd_data( *data++ );
		count --;
I got this code from a demo file.
If anyone can help me understand this code better, I would really appreciate.
Thank you.
Hai
I iam also getting difficulties in the lcd code, if you solved the code,and with you have a working file for 16*2 lcd,
please post...
