LCD 16*2 Data Sequence Flow chart
Fan174
Good evening to all
I am not speaking about code I want to understand communication between MCU and LCD how does microcontroller send data to LCD so I made one flow chart that explain my understanding
I have attached PDF file and I am looking advice with my flow chart
  • LCD Data sequence.pdf
Have a look on datasheet pinout waveforms of the LCD you are talking about (presumably based on the HD7780 chipset) and you will have a better understanding of the whole process, it just describes what the above flowchart depitcs for example for the writing command:
Reactions: Fan174
    Fan174
RS=0; // Select the Command Register by pulling RS LOW
RW=0; // Select the Write Operation by pulling RW LOW
EN=1; // Send a High-to-Low Pusle at Enable Pin
Wait = 450 ;
Confusing description. Actually E is pulsed high for Pweh >= 450 ns.
E is pulsed for each byte read from or written to the LCD controller. In so far I don't understand why it's described only as prepare action in your diagram.
Reactions: Fan174
    Fan174
What it should be ?
