I am not speaking about code I want to understand communication between MCU and LCD how does microcontroller send data to LCD so I made one flow chart that explain my understanding
I have attached PDF file and I am looking advice with my flow chart
Have a look on datasheet pinout waveforms of the LCD you are talking about (presumably based on the HD7780 chipset) and you will have a better understanding of the whole process, it just describes what the above flowchart depitcs for example for the writing command:
Confusing description. Actually E is pulsed high for Pweh >= 450 ns.
E is pulsed for each byte read from or written to the LCD controller. In so far I don't understand why it's described only as prepare action in your diagram.
