Layout of Differential Opamp
Puppet123
Full Member level 6
I am looking for resources including books, papers or even a screen capture from Cadence of the layout of a fully differential opamp.
Most books talk about single ended but not fully differential opamps.
Looking for either folded cascode or a two stage opamp.
If anyone has any papers, notes, or a screen capture from Cadence that would be very helpful.
What are the special considerations for fully differential as opposed to single ended layouts of opamps ?
Thanks.
... a screen capture from Cadence that would be very helpful.
Here's a 10 years old screen shot from a fully differential two stage S&H OTA, with its sample, feedback and compensation caps:
Don't know if this helps a lot - without schematic.
Stringent symmetry.
Thanks erikl.
Any way you can include the schematic - if not, what architecture of opamp is this (two stage opamp?) and what do each of C1 thru to C7 do - that would help...
Internal schematic of 741 op amp. Screen shot of Falstad's simulator. The circuit can be found in the program's pop-down menu. I added a 220 ohm load at the output terminal.
www.falstad.com/circuit
It contains:
* differential amplifier,
* current mirrors,
* output stage consisting of a half-bridge.
Green wires are positive polarity. Red shows negative polarity.
I think that's still company confidential - even after 10 years time, sorry!
Right, 2-stage fully diff switched OTA.
Top left caps C3 & C4 are compensation caps.
Top right caps C6 & C7 are serial connection caps from OTA outputs to CMFB input
Bottom C1 & C2 are the serial input caps
Bottom C3 & C4 are the feedback caps - all together they define the OTA gain (here: -1)
- they have to match very exactly
Bottom C5 & C6 are caps from the OTA inputs to vref
D are two dummies.
Thanks.
Are C3, C4 and C6, C7 MIM caps ?
What are the other caps, also MIM ?
Just rechecked with schematic: yes, all of them were MIM caps (type: cmim_sq ).
Hello erikl,
Thank you for your response,
Any reason one uses MIM Cap as opposed to MOS cap or MOM cap for analog / mixed signal layout for these capacitors ?
Thank you.
In contrast to MOS caps, MIM caps have negligible voltage dependency.
Same is valid for MOM caps, but due to their much thicker isolation layer they need a lot more real estate for the same capacitance.
Thank you erikl.
In your attachment (attached here again) you show the connection of the capacitor in what I assume to be a common centroid arrangement (the capacitors in the lower part of the figure).
I have seen many old layout books and papers show common centroid layouts of poly capacitors (I attached one), but you do you know of a book, paper or other resource that shows me how to do the common centroid layout of MIM capacitors ? I would like to know how to route and interconnect them properly when they are in a common centroid arrangement and cannot visualize it.
Thanks.
... how to do the common centroid layout of MIM capacitors ?
Why should there be any difference between the common centroid arrangement of MIM caps and that of any other device which needs high symmetry layout? - There is none, I think.
I would like to know how to route and interconnect them properly when they are in a common centroid arrangement ...
It is important not to disturb the high symmetry possible with common centroid layout by different lengths (capacitances) of the connection wires.
