LandLack
Member level 3
- Joined
- Aug 8, 2013
- Messages
- 54
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 8
- Activity points
- 526
Hi guys,
I would like to insert inside a Direct Modulated Laser a multitone RF signal;
the laser is this: http://www.suncityinc.com.cn/IMAGE/pro/PDF/DC-18GHz_DFB_LD_FIN.pdf .
Bias current has a different input than the AC signal current, so I would like to inquire the best DC current to give. The only thing I understand is that the DC current should have a high enuogh value to avoid "Clipping", but I don't know the other things to take into account.
Sorry for being long, but I've got a general theoretical knowledge and no experience on the subject.
Best Regards,
LandLack
1. Can you tell me the main issues of a laser, from this point of view?
For what I've been told (in general) the main issues are "Carrier power/Noise" and "IMN" (maybe Intermodulation?); 2.Can you tell me what are the sources of noises in my situation?
3. Also, is this Intermodulation referred to the combination of the (frequency) tones of the input, or the various wavelengths? If the second one is true, shouldn't I be safe from this point of view (since I'll use only a wavelength to transport the multitone signal)??
Best Regards,
LandLack
