Vigort
Member level 4
Hello All!
At modelling mirror aerials (frequency of 30 GHz, diameter of a mirror of 100 mm, a focal length of 50 mm and AirBox of 102x102x70 mm) HFSS gives out a following errors:
[warning] Solution Setup 'Setup1': Given the specified frequency and model dimensions, an extremely large mesh will be required to produce an accurate solution. Your model and/or frequency units may be set incorrectly.
The message disappears at only reduction of frequency.
Prompt, please as will get rid of this mistake.
Thanks
Thanks
