i have a project on lamp dimmer.
so i've brought a multi remote kit...and also a pot motor which i;m connecting to the dimmer.but i have no idea where the motor is connected or how this circuit wrks...
so please can anyone help me on this.?
thx
In common the H-bridge use Mosfet transistor instead of BJT transistors (as in your circuit) becuse it give more efficiency.
And don't forgot that Mosfet transistors can switch large currents so it suitable for large motors.
He means with "MultiRemote" that a circuit that can control (remote) many devices (using relay as in his schematic).
From his schemtic, The transmitted control signals are received from the IR sensor.
Then the microcontroller decode it and execute the proper function (such as turn on relay no. 3)
u mean at the output of the relay IC.
also the H-bridge works on 5 v dc and the voltage stabilizer is of 12-15v dc. i had this doubt that it wouldnt work on the same supply...can it?
have ne one of u tried this circuit before?
