ladder logic program for dol motor (system) with single push button in siemens plc
tnnazar
Junior Member level 1
Sharjah - U.A.E
ladder logic for dol system usually require 2 pushbuttons (one NO and one NC )
but i want to use only one push button(NO) for dol system..
when i press first time, the motor should on and it should remain on, when i release also..
when i press second time , the motor should off and it should remain off, when i release also..
The cycle should go on..
i need ladder logic for this above specified conditions.. ??????
thanks its working..
the input is pushbutton.. so in ur attached diagram 3rd line the output must be latched...
i tried in ladder and uploaded the the same...
I am interested to know other ways also...... so if anyone knows kindly share...
