kak111
STMicroelectronics
L3GD20 MEMS motion sensor: three-axis digital output gyroscope
Three selectable full scales (250/500/2000 dps)
I2C/SPI digital output interface
16 bit-rate value data output
8-bit temperature data output
Two digital output lines (interrupt and data ready)
Integrated low- and high-pass filters with user-selectable bandwidth
Wide supply voltage: 2.4 V to 3.6 V
Low voltage-compatible IOs (1.8 V)
Embedded power-down and sleep mode
Embedded temperature sensor
Embedded FIFO
High shock survivability
Extended operating temperature range (-40 °C to +85 °C)
ECOPACK® RoHS and “Green†compliant
https://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/DM00036465.pdf
Embedded FIFO
