[SOLVED] L3G4200D Gyroscope _ Measuring Angle!?
Jigar 4 Electronics
Full Member level 5
Full Member level 5
Hamilton, ON, Canada
www.facebook.com
Hello All,
I am making an IMU for 6DOF which has L3G4200D 3-Axis Digital Gyroscope.
I've checked so many Blogs, Forums, Application notes and have programmed accordingly to get the proper reading/information from my gyro.
Though I am very near to solve it - a single problem has made me mad since last two nights!
I've 16 bit digit - 1 signed bit + 15 bit value
Suppose I want to measure an angle with respect to X-axis at 2000 dps, for that I am doing the following:
X = X*70/1000; // X is of type int & having the 16bit value in it
Print(X); // to print X on UART
I am getting some values most probably <800 when I move gyro in counter clock direction with respect to X-axis and getting >4000 for the opposite direction!!
I want to have positive angle values while rotating it on counter clockwise direction and negative angle values for the clock wise direction... For that what I should add on my calculations?? [Angles should be in degrees 1 to 180 & (-1) to (-180)]
// in code 0.007 is in mdps which is the value of each LSB of gyro's data
What I should add in could and why I am having >4000 & <800 values right now?
Could anyone please help me with this?
Thank you so much for your valuable time.
I've observed(on internet) that everyone is getting +/- readings while I am not getting it.
so I've tried it with different data type...
and now I am getting +/- readings at both the side of the axis..
but still my main question is unsloved!
Can you tell me what should I do to getting the angles now???
should I take x1 at time t1 and x2 at time t2 and then :
X_angle = (x2-x1)/(t2-t1)
Am I right???
