gne_577
Junior Member level 3
Hello everyone.!
I'm making stepper motor control project with L297 and two L298 for stepper motor rated 2Amp capacity.These are parameter for L297
Reset pin 20 = 1 (+5V)
Pin 16 Osc = recommended circuit used as per datasheet
Pin 15 Vref = 0.36 V
Pin 11 Control = 1
Pin 10 Enable = 1
Current sensing resistor = 0.5 ohm ( 1 Ohm resistance 1 watt parallel )
Power Supply = 12 V , 2.1 Ampere
Motor Running = 1 Ampere ( By adjusting vref and sense resistor )
Now the motor is running very well forward and reverse.But I need Locking state in which rotor remains lock according to my application.
Now the problem is that after few minutes the motor getting very hot and L298 both near about to burn. I don,t know exactly what to do now..
Thanks in advance..
Pin 11 Control = 1
Pin 10 Enable = 1
Thanks in advance..
