Er Sanjit
Newbie level 3
- Joined
- Apr 19, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 25
Hello,
I am making rf based metal detecting robo and i had used 8051 for controlling the operation. The rf is fine and programming is also i think okay as i am getting desired outputs at 8051 output pins and L293 output pins.
The problems arise when i connect motors to the L293d's output pins,
1) ever if i get 8V at both sides of L293D, the motors didnt work when i connect them. ( the motors are fine )
2) when i connect one motor to L293D, then the motor works .. and on other side the output is 8V too ; but as soon as i connect the second motor too... the first motor also stops
3) If i keep running one motor with L293D, after 10-15 seconds the robo stops.
I am getting this problem first time in my experience. I have no guide / partner, so i am sharing it with you people. Hope, someone here will help me please.
and can this be problem that I have used only one 9V battery on the entire circuit of 8051-L293D and H12D ( RF IC )??:?:
but also the output is 8V on L293D,
then why the motors are not working:?
Please help as i had to make my robo work asap.
Regards,
Er S
Regards,
Er S
