Isuru Senarath
Member level 2
Hi all,
I am doing a project regarding bus route information system, This is my program. I need to get the enter key number for following FOR loops. How can I filter that. How can I get the pressed key instead of
if(SBUF = 1)
Task 1
else if(SBUF = 2)
Task 2
else if (SBUF = '*')
Task 3
How can I clear the SBUF ? :!: I want to clear the SBUF before I enter the message which I need to send through the GSM module. How can I do that in Task 3. Following is my full program.
Thanks
if(SBUF = 1)
Task 1
else if(SBUF = 2)
Task 2
Task 3
Thanks
#include <REGX51.H>
#include<string.h>
#define COL P2
#define ROW P0
sfr LcdData = 0x90; //LCD Data Pins
sbit RS = P2^5;
sbit RW = P2^6;
sbit EN = P2^7;
//Function Prototype Declaration
void lcd_data_string(unsigned char *str);
void lcdcmd(unsigned char value);
void lcddata(unsigned char value);
void Delay(unsigned int itime);
void SerTX(unsigned char);
void SMSString(char*text) ;
unsigned char msg[] = "Enter Info:-";
unsigned char keypad[4][4] = {'1','2','3','A',
'4','4','6','B',
'7','8','9','C',
'*','0','#',':'};
void main()
unsigned char colLoc,rowLoc;
unsigned int len,i;
LcdData = 0x00; //Port-1 as Output Port
TMOD = 0x20; //For Baud Rate Generation
TH1 = -3; //Baud Rate of 9600bps
SCON = 0x50;
TR1 = 1; //Start Timer-1
//LCD Initialization Commands
lcdcmd(0x38); //Initialize LCD Commands
Delay(1);
lcdcmd(0x0E); //Display on Cursor Blinking
Delay(1);
lcdcmd(0x01); //Clear LCD
Delay(1);
lcdcmd(0x80); //Row 1 and First Column
lcd_data_string("Bus Route Info.");
Delay(10);
lcdcmd(0x0C0);
lcd_data_string("System Project");
Delay(10);
lcdcmd(0x01); //clear screen
Delay(1);
len = strlen(msg);
for(i=0;i<len;i++)
lcddata(msg[i]);
Delay(1);
lcdcmd(0x0C0); //Move to Second Line of the LCD
COL = 0x0FF; //Make Port-2 as Input Port
while(1) //Infinite Loop
do
ROW = 0x00; //Groud all Row's
colLoc = COL; //Read all the Columns
colLoc = colLoc & 0x0F; //Mask the Unused Bits.
}while(colLoc != 0x0F); //Check until all the Keys are released
do
do
Delay(2); //20msec delay
}while(colLoc == 0x0F); //Keep Checking for Key-press
//It may be possible that this key-press may be due to some noise-spikes in the circuit
//thats why we will check once again whether the same key is pressed or not.
//If not the whole loop will be executed once again
Delay(2);
colLoc = COL; //read all columns
}while(colLoc == 0x0F); //Wait for the Key-Press
while(1)
ROW = 0x0FE; //Ground First Row
colLoc = COL;
if(colLoc != 0x0F) //Column Detected
rowLoc = 0; //1st Row Selected
break;
ROW = 0x0FD; //Ground Second Row
colLoc = COL;
rowLoc = 1; //2nd Row Selected
break;
ROW = 0x0FB; //Ground Third Row
colLoc = COL;
rowLoc = 2; //3rd Row Selected
break;
ROW = 0x0F7; //Ground Fourth Row
colLoc = COL;
if(colLoc!= 0x0F)
rowLoc = 3; //4th Row Selected
break;
if(colLoc == 0x0E) //1110 This means that First column is Selected
SerTX(keypad[rowLoc][0]);
else if(colLoc == 0x0D) // 1101
SerTX(keypad[rowLoc][1]);
else if(colLoc == 0x0B) // 1011
SerTX(keypad[rowLoc][2]);
else if(colLoc == 0x07) // 0111
SerTX(keypad[rowLoc][3]);
//lcdcmd(0xC0); //Second Row
//Check Columns and send the Data to the LCD Screen:-
lcddata(keypad[rowLoc][0]);
lcddata(keypad[rowLoc][1]);
lcddata(keypad[rowLoc][2]);
lcddata(keypad[rowLoc][3]);
if(SBUF = 1)
lcd_data_string("Go to Bus Stand");
Delay(10);
lcdcmd(0x0C0);
lcd_data_string("Loc:A1 7.00 PM");
Delay(100);
lcd_data_string("Enter Next Stop");
Delay(10);
lcdcmd(0x0C0);
lcd_data_string("Number");
Delay(100);
else if(SBUF = 2)
lcd_data_string("BS 2 at 7.10PM");
Delay(10);
lcdcmd(0x0C0);
lcd_data_string("ACHIVE? Y/N?");
Delay(10);
else if (SBUF = '*') //* is for Y (YES)
SMSString("AT\r"); // AT commands to initialize gsm modem
Delay(50);
SMSString( "ATe0\r"); // turn off echo
Delay(50);
SMSString( "AT&W\r"); // save settings
Delay(50);
SMSString( "AT+CMGS=\"0718021336\"\r");//my mob number here
Delay(50);
SMSString("7.10");
Delay(500);
SMSString("0x1A\r");
Delay(50);
LcdData = value;
RS = 0;
RW = 0;
EN = 1;
Delay(1);
EN = 0;
LcdData = value;
RS = 1;
RW = 0;
EN = 1;
Delay(1);
EN = 0;
unsigned int i,j;
for(i=0;i<1275;i++)
for(j=0;j<itime;j++);
void SerTX(unsigned char x)
SBUF = x;
while(TI == 0);
TI = 0;
void lcd_data(unsigned char item) // Function to send one byte data to LCD
LcdData = item;
RS= 1;
RW=0;
EN=1;
Delay(1);
EN=0;
return;
void lcd_data_string(unsigned char *str) // Function to send string to LCD
int i=0;
while(str[i]!='\0')
lcd_data(str[i]);
i++;
Delay(10);
return;
void SMSString(unsigned char* text) //function to send SMS using GSM modem
while (*text)
SerTX(*text++);
