Keyboard interface using MCU
avinash_h_dil@yahoo.com
Dear Friends, m supposed to design keyboard using MCU. Data fetched from keyboard has to be sent through SPI. now my question is, is there any need to use UART to TX/RX data through SPI??
Kindly answer....
Thanks in Advance...
Avinash
Well my advice is that any one wuld work fine. Since u aare interfacing a keyboard with the microcontroller then u can just make of the SPI pins instead of the rx/tx.
Well my advice is that any one wuld work fine. Since u aare interfacing a keyboard with the microcontroller then u can just make use of the SPI pins instead of the rx/tx.
U mean interfacing SPI directly to MCU??
Thank you..
Typically an SPI hardware interface is provided by a dedicated hardware peripheral module which provides Synchronous Serial communications.
The UART is an Asynchronous Serial communications peripheral module.
What specific microcontroller are you using in your design?
BigDog
You should do this by controlling the port pins and NOT by using a UART.
