saviour2009
Newbie level 3
- Joined
- Feb 15, 2010
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Bangalore
- Activity points
- 1,303
I am using a monopole antenna and trying to verify its resonant frequency using an HP8753D VNA. The process I am using is as explained below:
1. Calibrate the VNA using S11-1 port calibration method.
2. Connect the antenna using a co-axial cable to the VNA and check the S11 parameter graph over the frequency range.
3. For a length of 7.6 cms, I should have resonant frequency around 1 GHz, however I am also getting larger dips at higher frequencies (at around 3.5 GHz). As per the logic I should only have a dip at the resonant frequency.
Please advise what could be the possible reason behind the above mentioned situation.
Thanks...!!
Thanks...!!
