disisku_22
Member level 3
Hi all
I have 2.4GHz transceiver reference design witch is 4 layer microstrip PCB design.
But due to the cost and customer requirements i need to transfer these on to 2 layer PCB
Reference design has 0.4mm PCB thickness and 35um copper thickness.
I am planning to use CPW ground PCB design with 0.8mm board thickness with 35um copper and according to these RF track thickness will be changed(using TXline calculator).
Please suggest if there any other changes required other than the above and what are all the parameter should I required to take care while transferring from 4 layers to 2 layers in RF PCB circuit
Thanks and regards
Thanks and regards
