Issues:Converting VC++ 6.0 projects to visual studio 2005
deodatt
Newbie level 2
pune
I need to convert my existing vc++ 6.0 project to visual studio 2005.
This is my second project to which I am trying to upgrade, but there are new some problems that i am facing..
lot of errors i have resolved in this conversion or upgrade.
please help me in resolving these errors as this may help lot of people in trouble.
I hope all people who will reply to this post will continue to post the Replays to all the related errors to contribute Collaborated effort :)
posting one error here:
1>d:\extendedmfcclasses\source\basedialog.cpp(69) : error C2440: 'static_cast' : cannot convert from 'void (__thiscall CBaseDialog::* )(WPARAM,LPARAM)' to 'LRESULT (__thiscall CWnd::* )(WPARAM,LPARAM)'
and in .cpp file it points to this line.
BEGIN_MESSAGE_MAP(CBaseDialog, CDialog)
//{{AFX_MSG_MAP(CBaseDialog)
ON_BN_CLICKED(ID_DEFAULT_HELP, OnHelp)
ON_WM_HELPINFO()
ON_MESSAGE(UM_FW_CHANGE_MESSAGEBOX_POSITION, ChangeMessageBoxPosition) //}}AFX_MSG_MAP
ON_REGISTERED_MESSAGE(_afxMsgMouseWheel, OnRegisteredMouseWheel)
END_MESSAGE_MAP()
This code works fine in VC++ 6.0 however it gives this error while building in Visual Studio 2005.
thanks in advance for reply..
deodatt
Newbie level 2
pune
Re: Issues:Converting VC++ 6.0 projects to visual studio 200
microKernel said:
11-Jun-10 02:33 AM
Hi friends, I think I have got the solution for this problem.
here what I had to change lies in the declaration and the definition of the function ChangeMessageBoxPosition.
I had to change the return type of this function from void to LRESULT.
Conclusion:
I think that whenever we are facing the problem related to 'static cast' and in error if we get the reference to or pointers to sdk library or MFC library saying " cannot convert to...." then we should see first the return types and then the receiving parameters also.
My this conclusion may not be correct for every situation but I think that this may help to some people.
I will regularly post all the errors I get and if I get the solution for them, I will post them too.
microKernel, Thanks and I appreciate your reply.
-Deodatt Deo.
