Issue with non-scan DFF in scan chain
feel_on_on
Full Member level 5
there is non-scan DFF in my scan chain .
my scan chain length is 2000, scan pattern simulation is not pass.
and I found there is several non-scan DFFs was stitched in the scan chain .
Anyone can tell me the reason ?
pramod_gayakwad
Newbie level 1
Re: scan chain for DFT?
In scan chain always there should be scannable flops. Non scanable flops are connected to output of scannable flops. But as U told there is all non-scannablr flops in scan chain, that means your scan stitiching was done incorrectly. Please check with your scan style, scan mode.
satya_422
Member level 3
hi,
i hope you did not pass the scanability check so they are not converted in to the scan flipflops
feel_on_on
Full Member level 5
scan chain for DFT?
I mean that several non-scan DFF,not all.I want to know why Design Compiler not replace these non-scan DFF with scan DFF,why stitch them in a scan chain?
sam536
Full Member level 5
Tokyo
Did you check the post dft_drc report. Does it have any Warnings?.
Once i encountred this type of issue when i was using DB mode. The reason was some modules are applied set_dont_touch attribute and cells was not replaced as scanalbe cells. check this point if its applicable..
if you have problems in analyzing the warnings,share dft_drc report or warning list in dft_drc with us.dft_drc report will definilty let you know wahts the cause for ur problem...
There are ways to exclude the flops of your interst in DB(set_scan_exclude ..) as well as XG mode (set_scan_config -exclude_elements ).
Regards,
Sam
rudrad
Newbie level 3
If you give option set_scan_configuration -insert_shift_registers true then some flops which are one after other without any combo in between will not be scan replaced but this is correct and it will pass simulation.
dft_guy
USA
rudrad is exactly correct - the synthesis tool will use shift registers and other flop stages without combinational logic between as is, without explicit scan replacement, I believe, by default.
I don't know about that 'set_scan_configuration -insert_shift_registers true' - maybe in an old version - but the proper way to do it explicitly these days is a 'set_scan_group' command.
John
for DFT talk/info, go to
DFT Digest
DFT Forum
kiranks9
Member level 3
once u done the scan insertion, check the report properly. if non scan cells are stiched with scan cells it means scan stiching not happening properly. check with proper dc commonds
