sabu31
Advanced Member level 1
Dear All,
I need to give a burst of PWM for some duration and then turn it off for a half bridge inverter.
The PWM is generated using TL494 and the driver used is 2EDs8265hxuma1. A microcontroller signal (3.3V) is used for disabling/enabling the driver. However, once the driver is disabled (by giving high input to it), the driver does not get enabled. What could be the issue. The Vcc input to the driver and TL494 is 12V.
Thanking you.
Thanking you.
