Issue in Analog input in PIC16F877
ecaits
Member level 4
Member level 4
Dear Friends,
I am working on PIC16F877 with hi-tech c compiler.
I have used 0-5V analog input but in field, I am getting 4-20mA output.
Can I use 4-20mA as analog input or I need to convert 4-20mA to equivalent 0-5V??? How can I use it???
Plz suggest me.
Nirav
You should covert 4-20mA to 1-5v, I suggest you to place a 250 Ohms and read the voltage on the resistor.
If you want to use 4-20 mA then set the Vref as small possible and input resistor also as low possible
