ISR is not a label ISR isn't even listed in pic basic pro compile book
rayel
Newbie level 5
Newbie level 5
Hi
I found this program in the pic basic pro book listed here on this site so I assumed the programs should run ok
but I run across this problem as soon as I typed in compile ISR is not a label . what am I doing wrong
im sure everything is typed in ok and I am using the pic6f628 . I took a screen shot of the errors and if
you look below the 1st error there are several more all the way down to line 52
here is the screen shot
I uploaded the image but don't see it I hope it goes through am new at this site and I am still learning
Thanks Rayel
Here is the program
'*  Name  : 7 seg test from pic basic pro chapter6.5.BAS *
'*  Author  : ray        *
'*  VIEW...EDITOR OPTIONS]                                              *
'*  Date    : 9/26/2013                                                         *
'*  Version : 1.0        *
'*  Notes   : using pic16f628      2 digits 0 to 99                   *
define osc 4
define oscal_2k 1
cmcon = 7
    Digit var byte	                 'Value of number to be displayed
    Mask var byte	                 'Mask of number to be displayed
	W var byte	                     'temporary variable digit
	i var byte	                     'temporary variable
	LEDDis1	var  PORTA.1	         'Transistor for ones digit
	LEDDis2  var PORTA.0	         'Transistor for tens digit
	TRISA=%00000000	                 'all pins of port A are output
	TRISB=%00000000	                 'all pins of port B are output
	LEDDis1=0	                     'ones digit is off at the start
	LEDDis2=0	                     'tens digit is off at the start
	INTCON = %00100000	             'Enable interrupt TMRO
	OPTION_REG  = %10000000          'Initialization of presraler
	On Interrupt Goto ISR	          'Interrupt vector
	INTCON = %10100000	              'Enable interrupts
	W=0	                              'Initialization of variable W
Main:	                              'Beginning of the program
	for i=1 to 99	                  'Print values from 0 to 99 displayed
	W=W +l	                          'Increase variable W
	Gosub Prepare	                  'Prepare value from W to be displayed
	pause 500	                      'Pause to see the digits
	next i
	goto Main	                      'Print values from 0 to 99 again
Prepare:
    Digit=W dig 1	                  'Value of ones is put to var. Digit
	Gosub bin2seg	                  'Converting digit to mask
	Maskl=Digit	                      'Mask 1 contains the mask of ones
    Digit=W dig 0
	Mask2=Digit	                      'Mask 1 contains the mask of tens
	Return	                          'Return from subroutine
bin2seg:
	Lookup Digit,[$3F,$06,$5B,$4F,$66,$6D,$7D,$07,$7F,$6f],Cifra
	Return
Disable	                          'Disable interrupts while ISR is executing
ISR:
	PORTB=Mask1	                  'Put a mask of tens digit to port B
	LEDDis2=1	                  'Print the ones digit
	pause 1                       ' hold it printed for 1 ms
	LEDDis2=0	                  'turn off the tens digit
	PORTB=Mask2	                  'Put a mask of ones digit to port B
	LEDDisl=1	                  'Print the ones digit
	pause 1	                      'Hold it printed for 1 ms
	LEDDisl=0	                  'turn off the ones digit
	INTCON.2 = 0	              'Clear TOIF flag
                resume            'return to program
	Enable	                      'Interrupts  are enabled again
	End	                          'End of program
It is giving some other errors. Where is Mask1 in code?
Code - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
'* Author : ray *
'* Version : 1.0 *
define osc 4
define oscal_2k 1
DEFINE INTHAND myHI_ISR ' Assign High Priority Interrupt Service Routine label
DEFINE INTLHAND myLP_ISR  ' Assign Low Priority Interrupt Service Routine label
    cmcon = 7
    TRISA = %00000000    'all pins of port A are output
    TRISB = %00000000    'all pins of port B are output
    LEDDis1 = 0  'ones digit is off at the start
    LEDDis2 = 0  'tens digit is off at the start
    GOTO main
On Interrupt Goto myHI_ISR   'Interrupt vector
myHI_ISR:
    PORTB = Mask1    'Put a mask of tens digit to port B
    LEDDis2 = 1  'Print the ones digit
    PORTB = Mask2    'Put a mask of ones digit to port B
    LEDDis1 = 1  'Print the ones digit
    LEDDis1 = 0  'turn off the ones digit
    for i = 1 to 99  'Print values from 0 to 99 displayed
    W = W + l    'Increase variable W
    next i
Prepare:
    Digit = W dig 1  'Value of ones is put to var. Digit
    Mask2 = Digit    'Mask 1 contains the mask of tens
bin2seg:
    Return
End  'End of program
hi Jay
I just ran mine with the line numbers it came up line46
yours is on line68 but it says maks2 mine is mask 1
how did you get the expanded view ???
I also put a remark statement in front of ((goto ISR) your line 35 but yours
is worded different then it gave me an error on your line59 ((w=w +1))
it just seems to be giving me nothing but syntac error or bad statement
Thanks Ray
Code - [expand]
Mask var byte
Mask is declared as byte but not used. Mask1 and Mask2 is not declared but used in code. Post the link for original code source.
One error. Are you sure the code works? Digit is declared as byte and the name of lookup (array) is also Digit. maybe it is causing the problem.
Code - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
'* Author : ray *
'* Version : 1.0 *
define osc 4
define oscal_2k 1
    cmcon = 7
    Mask1 var byte   'Mask of number to be displayed
    Mask2 var byte   'Mask of number to be displayed
    GOTO main
    W = 0    'Initialization of variable W
myHI_ISR:
    LEDDis2 = 0  'turn off the tens digit
        W = W + 1    'Increase variable W
    next i
Prepare:
bin2seg:
    Return
End  'End of program
