Hello, during implementation in ISE PN (specifically during fit) the program is unexpectedly turns off, without any error or warning. Does anyone know why?
what OS are you using (also version 32 or 64 bit). Which version of Java you has installed (also number and 32 or 64 bit)? How much RAM you has installed and what CPU?
I'm not sure if ISE was ever ported to work on Windows 10. 14.7 is the last version of ISE and it was released before Windows 7 came out.
I would check the ISE 14.7 release notes/docs to see if they have a version that supports Windows 10. They may have created one as they still sell some of the older parts and you can't buy a PC with a older version of Windows.
You could always install ISE on a Linux partition and dual boot or use a Linux/Win7 VM.
I don't know if it is supported on Windows 10, but I am using it on this OS. There are problems with 64-bit version - similiar to that described by coleague making this post.
I am using 32-bit version and it works OK on Windows 10 (64-bit), but is working noticeable slower than 64-bit version of ISE.
