bikash123
Member level 2
- Joined
- Feb 19, 2012
- Messages
- 48
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Tezpur University
- Activity points
- 1,672
unsigned int j, i ;
char disp[10];
// Software I2C connections
sbit Soft_I2C_Scl at RC3_bit;
sbit Soft_I2C_Sda at RC4_bit;
sbit Soft_I2C_Scl_Direction at TRISC3_bit;
sbit Soft_I2C_Sda_Direction at TRISC4_bit;
// End Software I2C connections
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
void Write_Rom() {
Soft_I2C_Start(); // Issue start signal
Soft_I2C_Write(0xA0); // Address PCF8583, see PCF8583 datasheet
Soft_I2C_Write(0); // Start from address 2
Soft_I2C_Write(10);
Soft_I2C_Stop();
void Read_Rom() {
Soft_I2C_Start(); // Issue repeated start signal
Soft_I2C_Write(0xA1); // Address PCF8583 for reading R/W=1
j = Soft_I2C_Read(0); // Read weekday/month byte
Soft_I2C_Stop(); // Issue stop signal
void Init_Main() {
TRISB = 0;
PORTB = 0xFF;
TRISB = 0xff;
ADCON0 = 0; // Configure AN pins as digital I/O
ADCON1 = 0;
C1OUT_bit = 0; // Disable comparators
C2OUT_bit = 0;
Soft_I2C_Init(); // Initialize Soft I2C communication
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD display
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
void main() {
Delay_ms(1000);
Init_Main();
// Perform initialization // j=1;
Write_Rom();
delay_ms(500);
Read_Rom();
IntToStr(j,disp);
Lcd_Out(1,1,disp);
//j=2
char disp[10];
void Write_Rom() {
Soft_I2C_Write(10);
Soft_I2C_Stop();
void Read_Rom() {
void Init_Main() {
TRISB = 0;
PORTB = 0xFF;
TRISB = 0xff;
ADCON1 = 0;
C2OUT_bit = 0;
void main() {
Delay_ms(1000);
Init_Main();
Write_Rom();
delay_ms(500);
Read_Rom();
IntToStr(j,disp);
Lcd_Out(1,1,disp);
//j=2
