The facts I know:
1. It is linux projects , so must have linux or have to use cygwin (linux emulation under windows)
2. The project is very ambitious and is implementing in Berkeley university.
3. I tried it 4 years ago was very mature but from the Berkeley decided to start using java and they started to rewrite the code.
4. Currently I don't know if the java version can be used for the real work ... but you can download the old (classical ptolemy-not java version) as well
5. It is quite open can write your own code in order to expand the functionality ... but linux development experience are needed.
6. Ptolemy is used as a core in the Agilent’s ADS system (quite expensive)
Please let me know if the current version is good enough!
I found two nice simulation envirements .One is a clone of MATLAB called octave is uses the same syntax . The other is SCILAB .. both have open sources .. i have the idea to port the SIMULATION KERNEL to POWERFUL DSP and use M files directly to do DSP real time pocessing !
No compilation .. Just download and execute IN FLOATING POINT mode
The MATLAB functions will be optimal already ! And to my surprise both implement PVM so it will be possible to create parallel DSP computing enviroments.
Scicos is a FRENCH enviroment VERY POWERFUL and free TO SIMULATE dynamic and HYBRID systems .. It is possible to produce C code with a tool called COMEDI CODEGEN ..
So there is an alternative to SYNTHETISE C code for DSP from a MATLAB compatible ENVIROMENT / Now i need to see if is possible to Synthetise vhdl from the same SOURCES ..
About scilab: I have tried it in the past, it is quite powerful indeed, Now i see that they have put simulation tool like simulink in it. It offers matlab alternative but in my opinion should be used only if you don't have (can not afford) matlab on your PC!
i am interested in simulink, and have to do dsp simulation in simulink.
how can i get accoustomed to the tool.
are there any sites that have useful info??
