Is there any quickway to get valid data from the GPS of SIM908
krishnakumar.r93
Member level 2
Hi all,
I use SIM908 for my GPS application.
I use the following AT commands:
AT+CGPSPWR=1
AT+CGPSINF=32
AT+CGPSRST=0
Everytime, after i've turned on the GPS i have to wait about 15-20mins to get the valid gps data. Until then i keep getting:
$GPGGA,000204.001,,,,,0,0,,,M,,M,,*4F
$GPGLL,,,,,000204.001,V,N*7D
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPGSV,1,1,00*79
$GPRMC,000204.001,V,,,,,,,,,,N*4A
$GPVTG,,T,,M,,N,,K,N*2C
I use 12v/2A adapter to powerup my board. The voltage on the VBAT pin is 4v. I also use an active GPS antenna that requires 3v-5v, so i've connected the GPS-VANT-IN pin to the VBAT pin of SIM908.
All is well, but my only problem is that it takes too long to get valid gps data.
Is there any QUICKER WAY to get valid data from the GPS of SIM908..?
THANKS IN ADVANCE
what you are looking for is a WARM START UP so try changing to AT+CGPSRST=1 or try maybe =2, the manual states that it's better to make a cold reset the first time (=0 like yours) but after that, subsequent resets could be =1 (some pages states =1 is auto, another page states that =1 is hot and =2 is warm)
sadly this module doesn't say exactly how it's achieved, but in other GPS modules usually you fed the module with a known location, to help it to fix its location faster than from a cold (unknown) location... maybe this SIM908 module save its last location and uses it by itself... (maybe you need the RTC coin battery?)
Thank you Kurenai_ryu. But if you dont mind, can u define clearly between "warm reset" and "cold reset".
Hello!
Cold reset is when you start the GPS without any hint of the position. Therefore, it takes time.
Warm reset is when you have hints about the position (e.g. if you have stored the last position
when powering off).
That said, I don't think 20 min is normal. The GPS I use are able to connect (cold start) within
less than 1 minute in open air. And in my lab, depending on where I am, it can take linger.
It's fast when I'm close to whe window, for example. So first try to connect when you are outside
and see how it works.
Dora.
15-20 Minutes is too high period to get data from the GPS module. The time GPS will take to provide a data after power on will be in terms of seconds. So try to test with other GPS module if available. Make sure how much time does the GPS module takes to stabilize. If it takes very less time then the problem lies in your code to read the data.
Hello!
when powering off).
Dora.
is there any way to save the location?
if yes, please tell me how.!
@hobbyckts.
Thankyou.
i check the working of gps through terminal before i interface it to the MCU. so i believe that the code has nothing to do with it.
Yes!! That will give you a brief idea about the stabilization. If that works fine then you can workout on your code.
I presume you already reviewed the SIM908 AT manual. There's no means to restore position information by software. The usual way is to keep the module powered in powerdown mode. As already mentioned, you must not perform a GPS cold reset when the module holds valid position data.
Did you check if the GPS antenna sees a reasonable number of satellites after finding the position?
