Nov 7, 2006 #1 0 020170 Full Member level 4 Joined Jan 31, 2005 Messages 231 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 2,221 I used to hspice in linux. However I have no any waveform plot program to view result file like *.tr0, *.sw0, etc under linux. I used some waveform program in Windows, But too slow and No compatible with linux kernel. Question: Is there any waveform viewer program to view hspice result files under linux? I used Redhat linux 9.0. thanks.
Nov 7, 2006 #2 H Hughes Advanced Member level 3 Joined Jun 10, 2003 Messages 715 Helped 113 Reputation 226 Reaction score 26 Trophy points 1,298 Activity points 5,984 1. CosmosScope 2. Spice Explorer 3. GPLed tool: gEDA has a waveform tool.
Nov 7, 2006 #3 0 020170 Full Member level 4 Joined Jan 31, 2005 Messages 231 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 2,221 But I want to light and free-ware program.
Nov 7, 2006 #4 H Hughes Advanced Member level 3 Joined Jun 10, 2003 Messages 715 Helped 113 Reputation 226 Reaction score 26 Trophy points 1,298 Activity points 5,984 Spice Explorer is light, but not free. gwave from gEDA is free and light.
Nov 8, 2006 #5 R Ragnarok83 Member level 3 Joined Sep 6, 2006 Messages 65 Helped 10 Reputation 20 Reaction score 1 Trophy points 1,288 Location Colombia Activity points 1,626 gwave, download it, and put .option in your circuit script, compile and check the output for the graphics files that you should open with gwave.
Nov 8, 2006 #6 0 020170 Full Member level 4 Joined Jan 31, 2005 Messages 231 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 2,221 Do I have to add some option statement in netlist file to use gwave?
Nov 8, 2006 #7 R Ragnarok83 Member level 3 Joined Sep 6, 2006 Messages 65 Helped 10 Reputation 20 Reaction score 1 Trophy points 1,288 Location Colombia Activity points 1,626 You should put a .OPTION POST=2 command in your spice netlist, and it will generates the graphics files when you compile (for example file.ac0(AC analysis) or file.ic0(DC analysis)), and you open gwave and call from there these files.
Nov 8, 2006 #8 H Hughes Advanced Member level 3 Joined Jun 10, 2003 Messages 715 Helped 113 Reputation 226 Reaction score 26 Trophy points 1,298 Activity points 5,984 020170 said: Do I have to add some option statement in netlist file to use gwave? Click to expand... No special options is needed. Just add option to generate data file, as Ragnarok83 stated.
