Is there any methodto display ohm on lcd with adc 0804
desmond
Member level 1
hi all
Is there any method(program) to display ohm on lcd with adc 0804..........i have no idea.....can I do that ???
thx a lot
You mean the word ohm or the symbol Ω ?
Amr Ali
Hi
i mean the value of ohm
Added after 1 minutes:
is it possible to do that ???
You will print numerical values, right?
Amr
desmond said:
hi all,,Is there any method(program) to display ohm on lcd with adc 0804..........i have no idea.....can I do that ??? thx a lot
I guess you missed the micro in between. A LCD can be interfaced only with a microcontroller which is interfaced to the ADC. Yes you can do that but you need to write a source code for the micro and display the value on the LCD. Keeping the Ω constant, you may change K/M in respect to the values...Cheers
for example..............i would like to read the value let say 100 ohm resistor display on lcd............is it possible ???
and how to connect with 8051 and adc 0804 ??? is it just like the connection as voltmeter ???
Yes..why not? Display 100 and keep the Ω as constant. But you'll have to write a source code for the 8051 to do that.
You'll have to connect those pins which will communicate with the ADC for which they are programmed. Why the voltmeter came in between?:idea:
Hi pranam77
i cant use the voltmeter, cos my sensor is limited to current..............so what i can do is measured the ohm instead of voltage..........
can u give me some hint how to connect to 8051 and adc 0804 ......
by the way....i have write some source code to display the voltage......is it the same way to do it to ohmmeter ????
thx a lot
Hi desmond,
You can use your ADC0804 with +/- 5V input for full sensing range, or 0...+5V input with some basis value, pls refer to pages 13 or 8 and sensors datasheet too...
www.national.com/ds/DC/ADC0801.pdf
You will receive the circuit from me.
K.
