is there any function like fopen in vhdl or verilog
Robin Khosla
Member level 4
hii,
i want to create a bmp image using vhdl and then store it in pc so that i can watch the image
i know there is textio library in vhdl but it creates .txt files. How can i create bmp file?
is there any function like fopen in vhdl or verilog?
Writing data in and out of VHDL is technically possible, but how it works will depend on what similator you are using.
Luckily, modelsim/questa allows you access each byte of a file via chars. You need to declare a file of type character:
type char_file_t is file of character;
and then you can read and write to using the in built read/write functions for all types:
variable c_buf : character;
file my_file : char_file_t;
FILE_OPEN("somefile.bmp");
read(my_file, c_buf);
--do something with the char, like convert it to an integer with character'pos(c_buf)
Remember that BITMAPs have a specified header format, so you will have to read about all the fields in the header, which you will have to read and decode in your VHDL code.
