Is there a MCU that outputs 0 on all ports upon reset?
flashking
Full Member level 3
Hello mates
Is there a microcontroller that outputs low when it is reseted ?
the atmel 89c51 outputs high on all ports upon reset and that will make some trouble with my circuit
thanks
Just invert the output using diode? :)
Hello mates
thanks
AVR, PIC, etc..
thanks but gates and inverters would increase the complexity and the unreliability of the circuit,however if you know a reliable ic that works under moderate power then please help me
AVR, PIC, etc..
thanks I will try to use one of them
Your problem seems to be more that the IOs are configured as input after a reset. For an 8051 the output transistor (open collector)
is open after a reset and you'll see a high because of the internal pull-up resistor.
When using e.g. a PIC there is no internal pull-up resistor. So this input pin (that's what it is after a reset) is floating between high and low.
The only thing you can do is adding an external pull-down resistor to have a defined low-level after reset.
That would be fine.
Regards,
Jerin.
When using e.g. a PIC there is no internal pull-up resistor. So this input pin (that's what it is after a reset) is floating between high and low.The only thing you can do is adding an external pull-down resistor to have a defined low-level after reset.
thanks for the details
but should I use the pull down resistor with the pic only or youe meant that it is good for bith 8051 and pic ? and do you suggest a value ?
I'm starting to sound like a salesman - sorry !
Try the mikroElectronica web site - they have a whole book online.
Also I highly recommend their free compiler/IDE.
jack
Just understand the instructions fro PIC & read the users manual for MPLAB. Do the code oe your own. Post the doubts here. Get it answered & keep ROCKIN!!!!!!!!!!!!!!!!!!!!
Regards,
Jerin. :) ;-)
