Alex Liao
Member level 4
- Joined
- Apr 8, 2013
- Messages
- 75
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Activity points
- 1,991
I have a comparator circuit. I have print out an waveform of the Vout+. The x-axis is the time and the y-axis is the voltage. For example the voltage supply is 1V. I can see when the voltage raises from 0V to 90% of 1V, which is 900mV, how much time is needed or what is the current time in ns when it reaches 900mV.
I am wondering if there is a function that can return you one specific point (in ns) on the X-axis when Y reaches 900mV. Thus I do not need to manually measure/observe it. Maybe I need specify any time range such that it can only return me one value because the output wave maybe periodical and thus there are lots of point satisfying this requirement of 900mV on y-axis.
I am using Cadence ADE to run simulation and hope there is a function in the calculator or any ocean script that can do this.
Thanks,
Alex
Thanks,
Alex
