Michael Weaser
Member level 3
I was looking for op amps for use with making active filters, and I found the NJM2068 dual op amp , as looking at the specs it has a pretty high GBWP of 27 Mhz ,but there is an issue it warns in the datasheet. It says in the datasheet it can have oscillation issues if you use a Capacitive type load , but can be fixed by adding a resistor in series at the output.
