is rf 433mhz ask module serial or ttl compatible?
sunnystar
Junior Member level 3
the simple and cheap RF 433mhz ASK module is serial or ttl/cmos compatible?
They are all serial compatible to be able to send data.
Whether it is TTL or CMOS comapatible depends on the actual design but if it runs from a 5V supply it almost certainly is.
Brian.
The 433 MHz ASK transmitter modules work from 3V to 12V but I don't know whether 12V can be given to DATA pin or not. You can provide 12V for VCC and %V TTL from uC to DATA pin of RF module (Transmitter). Providing 12V power will increase the range of transmission. For 3V I have obtained 40 ft transmission.
Is your RF modules like this ? They also come in Red color (Red color PCB).
https://probots.co.in/index.php?main_page=product_info&cPath=22&products_id=29
