a simulation result?surianova said:hi all!
my bandgap output noise is 400 uV rms for frequency from 1 to 1 Mhz,is it ok? pls comment.
400uV RMS sounds high to me, but it is difficult to say without more information. If you need any accuracy more than about 8-bit using the Vref, you are likely to run into problems with your noise level, depending upon your system and the actual bandwidth of your bandgap.surianova said:hi all!
JPR said:yorande,
If there is D/A converter or A/D converter using this reference, the noise on the reference will limit the accuracy of the conversion for most converter types.
An 8-bit A/D at 1.25V will have a resolution of 4.88mV, which relates to a quantization noise of 1.4mV. With 400uV RMS noise on Vref, there will not be excessive noise on the ADC value. However, if we had a 10bit ADC, the quantization noise would be 350uV RMS, which is about the same as the 400uV RMS from this voltage reference. Adding the voltage reference noise would now add significantly to the overall noise performance, limiting the accuracy of the ADC.
As to the bandwidth of the bandgap reference. In most cirucits, there is no need for wide bandwidth from the voltage reference circuit (it is a DC voltage level), so the output will typically have significant filtering applied, meaning that the bandwidth will be low. However, there are applications where the high frequency noise does not impact the results, so the bandgap would not be filtered, or some bandgap circuits that would have poor power supply rejection with filtering so the bandwidth needs to be wide. If this 400uV RMS stems from a wide bandwidth cirucit, then much of the noise will be at high frequencies and may not impact some A/D or D/A circuits (particularly sigma-delta type A/D). However, if the 400uV RMS is on a signal that is already heavily filtered, then the additional filtering from the oversampling type converter would not be of significant benefit.
As for the change in load, there are some circuits (such as an R-2R ladder type D/A) that can produce very different loads on the reference, depending upon the D/A code being converted. If the voltage reference is used with this type of variable load, then the load regulation of the converter would matter. I am not stating that the load regulation matters for ALL voltage references, it is simply a specification that might impact the ability to filter out noise.
My main point was that the noise level sounds high, but, without knowing more about the application or the bandgap itself, it is difficult to determine if it is a reasonable value.
