hkBattousai
I want to design a microcontroller based battery charger circuit. I'm planning it to work like this :
Charge the batteries for 59 seconds, then stop charging and connect a 4.7kΩ load for 1 second, and measure the voltage level at the end of this 1 second interval. If the voltage level is below the desired level, go on processing this 60 second interval, until batteries are fully charged.
Times and load specifications are given as an example, I will decide the optimum values later. Can you tell me if I can make a battery charger circuit with this method? How does the commercial models work, are they similar to my model?
