Is it possible to send 0x000 via usart?
shaun_c_m
Junior Member level 2
is it possible to send 0x000 via usart?
im using the 9 bit mode on the 16f877, but with all bits set to 0 the module seems to consider the buffer empty and doesnt send any data.
is it possible to trigger the module by using another command like a swapf or add?
thanks
0x000 via usart
Any movwf to the TXREG register will initiate a transmit.
9bit mode is pretty much not for RS232, you'll need special software on the PC end if that's what you're trying to talk to. I'm not sure the a standard PC UART supports 9 bit.
Re: 0x000 via usart
If you need to send 0x0000, you need to transmit 16bis->2bytes
Simple transmit 2 bytes and in the receptor put it in the right place in memory.
I had a similar problem, I needed to send 16bit unsigned integers to a PC, I simple send the 2 bytes(from PIC RAM) by RS232 to a PC, and in the PC soft I put the 2 bytes in RAM addresses of a unsigned int.
