Is it possible to design a Gm-C filter operating above GHz?
lcg22
Member level 5
Member level 5
I am required to propose a topic for pursuing M Eng. My supervisor suggests me to do some research on this topic. To my knowledge, it's almost impossible to design a Gm-C filter operating at such a high frequency. Anyone could give me some suggestion? Thank a lot.
Regards,
lcg22
The higher frequency that I have seen is about 400MHz, but depends on the filter order that you want to design.
Check this:
Seng-Pan U, R.P.Martins, J.E.Franca, “A 2.5 V, 57 MHz, 15-Tap SC bandpass interpolating filter
with 320 MHz output sampling rate in 0.35µm CMOS,” in ISSCC Digest of Technical Papers, Vol.45,
pp380-381, San Francisco, USA, Feb. 2002.
Regards, bastos
Check this:
Regards, bastos
Thanks, bastos.
I do search the literature for related subject, however, as the one you listed, all of the papers present filters operating at a frequency less then GHz.
bastos & lcg22,
I made a gm-c filter 4 years ago, 5th order, with highest BW 500MHz, for hard drive read channel. It's in .25u CMOS.
To operating over 1GHz, you'd better use <=.18u CMOS, or if you like, try SiGe. I don't see any reason why it can't.
I would like to recommend:
Y. Tsividis for a complete treatment of this topic
Nauta, Abidi for high speed design issues (early 1990)
It seems the design is kind well defined. You won't have too much room to dance.
LaTeX Commands Quick-Menu:
