Is it possible to decompile a labview executable (.exe)?
sassyboy
Full Member level 1
United Kingdom
labview decompiler
Hi, all! I have a piece of commercial labview-compiled software which a company has written specificly to my needs, but the company who supplied it has gone bust! The software contains several bugs and I would like to attempt to correct this. I guess the obvious way to do this is to decompile the .exe file back into LabVIEW codes and then correct the codes in LabVIEW, finally compile it back to .exe format. I have got the LabVIEW professional edition. I would be grateful if you would let me know if how I would decompile the .exe? Or is it possible?
Thanks in advance! Sassyboy.
labview to exe
Unfortunatelly, once compiled the LabView created executables can not be de-compiled to go back to VI(s) level ..
I wish you good luck in finding someone from that company who will be able to deliver to you LLB or VIs used to compile your application ..
Otherwise, you will have to create it from scratches ..
labview executable
Getting back the LAB View code seems to be out of reach. The only thing you can do to eradicate the bug is by using debugger (such as SoftICE) to trap the bug during execution, then analyse it using a disassembler (such as IDA Pro). This is the only way I can think of :(. Of course a little bit experience in reverse code engineering is needed to carry out this task.
Re: labview decompiler
How have you been doing? Are you using?
