vinothmct
Member level 1
Is flash memory RAM or ROM? RAM is temporary storage, data gets lost when power is turned off . In that case it will be ROM . Can anyone here explain this basic doubt . Program memory is flash memory right? Data memory is?
It depends on what you define, if you have a variable with data that is not going to change during execution then you can declare a constant variable and place it in the flash, the value can be read but not changed and is stored permanently (doesn't get cleared when power off).
Normal variables reside in RAM so the content is lost when you power off the mcu.
Sometimes we call flash a ROM but what it is actually is a non volatile memory which means that the content is preserved when power supply is removed.
https://en.wikipedia.org/wiki/Non-volatile_memory
The IDE stores everything in ROM (unless there are some values written in an internal eeprom too) then when the mcu starts up the variables that should reside in RAM are copied there at runtime.
Each time the mcu is disconnected from the power supply the RAM content is lost.
