Hello,
We have the following waveform in the STD1NK80Z FET (DPAK). It recurs every 10ms as shown.
or is it 7.6ms ??
We need to know if this violates the SOA.
To me, these pulses equate to repetitive pulses of [45V and 430mA and 650us long].
SO what is the power and duty cycle, d ?
How from the datasheet can we tell that this is acceptable?
Did you ever take Calculus and graphical integration?
The SOA graph on page 4 shows what’s acceptable for a “single pulse”……..but how are we supposed to know what’s ok for our pulse train?
Also, the SOA graph on page 4 says “Tj=150degC and Tc = 25degC”..
What does this mean?......surely it’s the junction temperature, Tj, that is the significant parameter, so why do they bother to specify that the case temperature, Tc, is at 25degc?
Because the thermal rise is determined by repetitive power and thermal resistance using an infinite case heatsink to isolate 1 thermal variable Tjc.. Of course, if case rises, so does junction by the same.
STD1NK80Z datasheet:
https://www.st.com/resource/en/datasheet/CD00058073.pdf
