[SOLVED] Is 1/2 Vss = floating
sharethl
Newbie level 5
Newbie level 5
An ADC datasheet said: if Pin4 is floating => DDR mode, if not floating => SDR mode,
The schematic I saw connected this pin to voltage divider to get 1/2 Voltage supply,
Is this ADC configured as DDR or SDR?
floating means pin is not connected, but what 1/2 Vss
Thanks.
Page 4 also describes how pin 4 works:
When this pin is floating or connected to 1/2 the supply voltage, DDR clocking is enabled.
edit: Oops, crosspost with FvM
Just read the text completely: "When this pin is floating or connected to 1/2 the supply voltage"...
Oh, Thanks. I did read that one, but for page 31, it didn't say that, then I forgot.
Have a great holiday!
