arup
Member level 2
Application : micro controller based AMF relay(Genset Controller)
Please refer the attached file for exact application the way IRFz44N is used.The subjected MOSFET is driving a external relay ( Freewheeling diode might not used across the relay coil) which in turn will be used for driving START solenoid of generator or driving hooter or driving a contactor.The supply is 12 V / 24 Battery.I am driving the mosfet using a ULN with pulse amplitude of 5 V DC(max).I am getting frequent failure of this mosfet from the field.What could be the reason & what way i could protect the failure of mosfet.Pls suggest.
regds
regds
