IR21362 Logicdrive for highside(HIN 1, 2,3) is 'in phase'.
whereas IR2130 it is outof phase.
there are other pin functionality differences.
and you cannot dropin 2130 instead of 21362.
HI
According to this diagram,P_ground and Logic Ground is separated?
I am confusing about between the COM and Vss.
and also separate C20 , C19 ground?
can I connect AGND with a resistor to P_GND
Separating COM and VSS suggested in the IR21362 datasheet, implementing a current sense resistor. But to make the current sense resistor work, DC- must be connected on it's left side. AGND is apparently a singular net, looks like a typo. In case of doubt, refer to the IR21362 datasheet.
