IR2130 problems in Proteus
evertonjr
Newbie level 3
HI,
i need some help on this simulation.
can someone tell me how fix de error "Timestep too small", or review my schematic.
tks
  • ir2130.rar
Did you try changing the simulation options from "Default Settings" to either "Settings for better convergence" or "Settings for better accuracy"? It can be done at Menu on System>>Set Simulation Options.
just tried but the error still happening. i think can be the input PWM (HIN1,2,3 and LIN1,2,3) they must have some phase lag but i dont know how to do that.
I can't open a .rar file on my tablet...
Klaus
hi,
The .rar is a simulation file in proteus. on the attachments is the circuit print.
tks.
  • ir2130.pdsprj.pdf
Why the zeners across GS?
The drive voltage is 15Vmax and the Mosfets can widthstand 20V.
I see no reason for the zeners ... also zeners often suffer from high capacitance.
V_SO is the power current return path for the low side drivers. They are not connected in your schematic.
Also check you other unconnected pins ... wheter this complies with the datasheet.
Klaus
hi
the reason to use a zenner on gate-source is to climp 18V on VGS, i take it off but still have problems.
I think is on input signals, how i do?
appreciate the help. TKS
