cdez
Junior Member level 1
hello,
I have build a half bridge motor controller with ir2110
I have made a first test, the half bridge worked good I accelerated decelerated a motor at 20khz with pwm coming from a microcontroler. The pwm is also inverted with the microcontroller with dead band delays of few microseconds for the second input.
But now I have a problem that appeared I don't know why: the low side mosfet heats up, and maybe the vcc-com capacitor.( I am not sure if the capacitor heats itself or it was heaten by the mosfet heatsink near it )
And also flowing current increases slowly, it changes all the time very weirdly.
(I don't remember all of this happening at the first test maybe I didn't test carefully.)
the motor has 0.08A without controler at 12v dc, with ~90% duty cycle using my controller it has 0.1A at beginning thens rises to 0.2A for no reason
mosfets are irfb7540, schotky diodes, 10 ohm gate resistors, blue caps 10uf and the bootstrap 100uf
here is a picture of my controller:
thanks
thanks
