Khaled Farag
I am implementing a half-bridge converter as shown in the figure.
The problem is that the low side channel has been blown many times (LO pin becomes short-circuited with VCC pin). The circuit works properly without problems at first, but when I stopped it and touched the IR2110 for checking its temperature and switched ON the circuit again , I found the aforementioned problem. This happens many times. So, any suggestions will be highly appreciated.
Note: I use IGBT (G20N60B3D) as the power switch and the switching frequency is 500 Hz and of course there is a dead time between the switching devices.
